Old 11-21-2005   #1
DIYMA Founder
Default Carputer eq/crossover software
http://kxproject.lugosoft.com/shots.php?language=en
Looks promising... and free!
npdang is offline
Old 11-21-2005   #2
H-Audio - AKA - Here-I-Come's Avatar
H-Audio Inc USA
National Product Director
Default Re: Carputer eq/crossover software
Yes it seems to be a very nice software and this thread is even more promising.
http://www.driverheaven.net/showthread.php?t=66801
The roomEQWizard is another nice software that does Room correction. I downloaded it, but I'm yet to play with much. If they get them to work together it would be great. My 8250 and two Alto mobile UCS Pros would in problem. I already have a carputer to control the UCS Pro's editing software, so I would only need a very good sound card with at least six stereo outs or 12 mono outputs.
roomEQwizard link
http://homepage.ntlworld.com/john.mulcahy/roomeq/
"Its All About What Sounds Right"
Mark A. Brooks
H-Audio Inc. USA
Website: H-Audio Inc USA
H-Audio - AKA - Here-I-Come is offline
Old 11-21-2005   #3
nice..i like how the roomeq is for os10 too:-D..im gonna try that
Hipnotic4 is offline
Old 11-21-2005   #4
Send a message via AIM to WeDgE
Just installed this on my home PC and now I don't have any sound at all...sweeet... :\
WeDgE is offline
Old 11-21-2005   #5
How do you get this thing to work? I can't hear anything now.
cotdt is offline
Old 11-21-2005   #6
yermolovd's Avatar
You have to go through all the docs... I had to do quite a bit of tweeking and changing settings before it worked. You have to screw around with that signal flow window, although it has to work fresh off after the install.
yermolovd is offline
Old 11-21-2005   #7
Send a message via AIM to Kramerica
Check your sound cards settings, with my sound card everytime I load room eq it mutes every input and output on my sound card excpet wave out. I also had to select record without moinitoring to get rid of some really bad feedback.
Kramerica is offline
Loudspeaker measurement software Airforceyooper DIYMA SQ forum - Technical & Advanced 8 07-08-2009 05:55 PM
OBD-2 software? MarkZ Off Topic 3 12-20-2005 09:47 AM
Carputer sound advice xencloud DIYMA SQ forum - Technical & Advanced 45 12-07-2005 05:00 PM
Need DIY Reccomendation for Carputer setup in RX7 1badrx7 DIYMA SQ forum - Technical & Advanced 11 11-22-2005 06:55 AM
System tuning software xencloud DIYMA SQ forum - Technical & Advanced 1 09-26-2005 10:24 AM
Second Skin Spectrum
SEO by vBSEO 3.5.1 PL1
