Hello folks
Hoping to get some thoughts. I've got two vehicles, 05 Camry & 97 F350 Crewcab. The sub that I have in the trunk of the Camry is a JBL GTO1014. The sub I have behind the rear seat in truck is a Kicker 07TCVT102. (First off I don't pretend either of these are top of the line subs). In my truck the base seems so well defined I can hear the plucks of the base just fine. In the car it sounds more "muddy" for lack of a better word. When I first put the sub in the car I had it facing forward right behind the rear seat. You couldn't hear it.
After reading I found that better results could be had to place it about 6" from the rear of the trunk facing the rear of the trunk. I tried that and it made a ton of difference. I moved the sub around the trunk facing different directions just playing around and found I could hear it best about 6" inches facing the rear so I've left it there.
I cut a panel to fit against the rear seat that fits the contour of the trunk to cabin area pretty good and I have my amps mounted to it. It's not completely air tight but it is a pretty good fit. I put the sub from my truck in the trunk of the car and it had a little more detail but not quite like it is in the truck. The trunk area is deadened pretty well as is the cabin in the truck.
I do think I made the box for the JBL a tad to small I forgot to account for the size of the speaker itself. After realizing this I filled it with poly fill. I didnt' really notice a difference. The Kicker came with it's own box that fit behind the seat in the truck fine so I've kept it like that.
I've done a lot of reading about IB set ups I don't know if that would offer more detail or not. I'm not sure if this is just part of the way it goes with subs in a trunk. There is no problem hearing it it just doesn't seem detailed. I actually thought the JBL would be more detailed. I know they're two completely different subs. I'm just not sure what I should be expecting with a sub in the trunk. I've heard other vehicles with subs in the trunk but the music they're playing it's mostly just pounding I'm not sure there could be any detail.
I like the tightness I have but I'm just curious if it realistic to expect the same detail as the sub in the cabin of the truck.
Anyhow any thoughts on this would be appreciated.
Alan
Alan
