I'm going to put four 12s in a box. I have two DVC 4ohm subs and cannot find a matching set to go with it. Although, I can get the same sub but they would be 4ohm SVC 12s. Is there a way I could wire them to a 2ohm mono amp and still get a 2ohm load from my amp?
Could I have the SVC subs wired in parallel then straight to my amp, then have the DVC subs individually paralleled and ran straight to the amp? Meaning, one wire coming from the 2 SVCs to the 1 channel amp, and then one wire from EACH of the DVCs ran straight to that same channel on the same amp.
Pics below...assume those are my four subs running to the same channel on amp instead of 3 different amps.
